Relayboard to Ms cable
menzzer37
Taking the simple case, no PWM and running high impedance injectors that measure 12 ohms, that would be approximately 14 volts/12 ohms= 1.2 amps
Low impedance injectors that measure 2.5 ohms with a dropping resistor of 6 ohms (what I usually run) would be approximately 14 volts/8.5 ohms = 1.6 amps
Those numbers are per injector so you can figure out depending on your engine and number of injectors along with how you wired them. This should be good for an approximation. Are there two injector wires in the DB37 or four, I can't remember off hand.
Thanks! That pretty much kills the idea. I have been talking with custom cable inc; they are building a quote for what a 20 awg 6' cable would cost. I'll keep this thread updated if it's halfway affordable. I think this would be a great option. They will sell in large quantities as well, so maybe a large group buy would be in order!
  • 3 weeks later...
