Alsil mount clarification
Beau M
So, I think that this is the plan for the Alsil mounts correct?
My question is about the "notes". Can someone explain them? What is supposed to be 1" and 7/8" away from what? The hole from the bottom of the bracket? I take it this will tilt the engine a bit?
All the notes in white are mine. The notes in red were added by someone.
This is an old design, and after the engine sat on the frame rails for a little bit it began to twist the rails, and the engine dropped almost 1". I designed a new one with 4" square tubing that just used the rail to bolt to.
I wouldn't use the seperate mounts unless you reinforce the frame rails substantially.
