Is the back plate (dust shield) really necessary on a 71' 240Z?
I have installed 4 piston calipers with drilled/slotted rotors on front of my 240Z. Is the back plate (dust shield) really necessary? I did a disc brake conversion on the rear and there is no back plate (after removing the old drum brake back plate). Is there some other purpose than a dust shield?
If not, I would just as soon leave it off. Opinions...
Thanks for the input.
I really could not see the need for the back plate when using higher performance braking components other than possibly water. The car will probably not see too many adverse weather conditions--although it will be driven!
Noted on the possible use of plates for brake ducting. Thanks.
