1972 datsun 510 wagon sr20det
LeX
i'm not too great with the project threads, but this is my project.
i bought it back in july 2008 and it's been in the shop basically since then. Due to bad luck and a shady shop nothing got done and i was able to get most of my money back. Right now I took it to my buds at Garage Zero and we are trying to get it finished up ASAP.
This is the car when I got it with my Riverside rims
interior is pretty complete. Just need a dash cap really and otherwise it's staying the way it is for now.
added the 280zx brake setup
motor swap going in the wagon
S13 sr20det from JHOT
the riversides
So far these are the plans, work being done, and mod list:
suspension/handling:
280zx front struts and brakes
slotted rotors
SS brake lines
Ground control coilover kit (to be purchased)
monroe sensatrac rear shocks (to be purchased)
rear 3" lowering blocks and ujoints (to be purchased)
RSB (to be purchased)
koni NOS adjustable inserts
FSB (to be purchased)
riverside wheels 15x6.5 +13 and 15x7 +3
195 50 15 fuzion ZRI tires
performance:
SR20det redtop motorset
5spd transmission
XTD stage 3 clutch
FMIC setup
Greddy oil filter relocation kit
3" turboback exhaust
forced performance T2 flange mitsubishi 20g turbo
external wastegate with dump pipe @ 14.7PSI
Megan heatwrapped topmount manifold
MSD inline fuel pump
Deatschworks 555cc fuel injectors
Blitz SS BoV
modified oilpan
custom driveshaft
aftermarket aluminum radiator
Emance tuned ECU
N60 MAF
on the exterior I am trying to keep it as a sleeper at least power wise. Minus the drop and nice looking wheels it should hopefully hide that it is making a lot of power with stock interior look and feel.
August 19, 2009:
today I ordered the right bolt pattern exhaust flange so a custom downpipe can be made. Also need to find a slightly narrower radiator which I have sourced (fiero radiator) which I will exchange the other one for at Summit Racing.
I need to buy a new front coilover ground control setup to replace what I have on there. I also need to purchase rear sensatrac monroe shocks and some lowering blocks and ujoints. That will deal with the suspension setup.
other things to do and to roll and the fenders, work on wiring and get exhaust and driveshaft made. Hopefully the car will be on the road by the end of the month. also need to work on finding a tachometer that's sitting around that I can install relatively inconspicuously.. as well as finding another boost gauge.
  • 1 year later...
  • 3 weeks later...
