280zx 2+2 turbo spring/strut options
azguy
Here is a call to anyone out there with a 280zx 2+2 turbo with upgraded springs and/or struts. Everywhere I look, all vendors show tokico etc. for a 280zx but then the dreaded "except 2+2". I can't find ANYTHING that specifically says it will work for the 280zx 2+2. I just want to know if anyone on here has used springs/struts for the 280zx on a 2+2 model and if they fit correctly and how they liked the results. Thanks guys!
I had a 280ZX 2+2 turbo for many years. I bought the Suspension Techniques set that said "not for 2+2"
It bolted right in and fit fine. The ride was great. The rear sat a little higher than the front. Cut 1/2 a coil or so off to correct this.
http://www.bleachgarage.com/images/z/purplez14.jpg
I see your in seattle..i am looking to raise the rear of mine..where did you get the springs?
