Help adding fuel system for nos
not the answer you are looking for, but.......
I mounted a 1 gallon fuel cell up front for my no2 wet system. summit racing sells 1 gallon fuel cells for cheap.
used a mallory comp70 to pump the fuel.
filled the 1 gallon tank with racing fuel.
1 gallon of fuel is enough for 1 ten pound bottle of n02.
I put it on the driver's side fender, up against the radiator inside the engine compartment. The alternator is on the passenger side so had room on the drivers side.
I keep the tank empty, except when I get to the track. so I 'm guessing it is fairly safe.
The nice thing is the ability to run racing fuel with the no2 shot, and only needing a few gallons of the stuff.
