L28et For Under 1500?
Killerpoon
  • 3 weeks later...
I will say it again......Ther is NO NEED for a 60mm tb at those power levels. If you want to do it just to do it or for the looks then by all means do it. It is just another cost.
+2! SHANE ran 11 second 1/4s with a factory TB. For 250-275 hp, all you need is intercooler and boost controller. And a factory engine/fuel system/turbo in good shape.
Stand-alone ECU makes good sense, and would make the above setup more dependable, especially with some larger injectors.
Edited by SleeperZ
