my build so far
  • Replies 82
Posted Images
  • 3 weeks later...
  • 3 weeks later...
the difference was night and day, but the problem with the edelbrock was that the secondaries weren't opening at all. something with the linkage was broken. so at higher rpm's the motor just bogged way down from running so rich.
I love the Holley carb. not only does it look good but it runs like a champ.
  • 4 weeks later...
for the throttle, i recommend you take off the gas pedal and weld a short piece of angle iron on the end of the pedal rod (under the dash). then put the carb cable of the end of that. This way the cable will have a straighter shot to the carb linkage. I have done this on 2 different v8 conversions and it works much better than snaking the cable to the carb.
However, you will need to drill another hole in the firewall to pass the cable.
