Luna: The cause of, and solution to, all of my problems
Thanks guys!
The diff came out of Arizona. Bought it from Cody Ethridge. Was sourced through the Datsun Parts and Needs group on Facebook.
Fairly boring update in the meantime.
Aside from fairing the dash plug, I've been slowly removing/inspecting the new differential.
IMG_20151111_203348149_HDR_zpsawlu8soi.j
Removing the no longer needed half shaft flanges.
Definitely need to order some new seals. Needs a general basic refresh before it can be mounted to the car. Overall condition looks nice though.
IMG_20151114_171226402_HDR_zpsjedigyl7.j
Destroyed seal - Cause determined.
I'll test breakaway torque when it is in the car.
Can't wait to clean everything up, and mount the finned cover with all new rubber and fluids. Mmmmm...But I'm getting ahead of myself...
...'Til then, I need to order some parts.....and continue sanding....ugh - Although the end is very near. I foresee one more spray before the final fair.
Then I layup the mold. Then results happen quickly!
Fun fun fun.
Worked for a moment this evening. Prepped the plug for the final spray/fair - no pictures of that, cause by now, we all know what it looks like. haha.
A few other odds and ends.
Since I am using the Nissan coolant temp sensor now, I finally got around to swapping pigtails in the harness, and calibrating Megasquirt to the OEM sensor.
IMG_20151116_183420303_HDR_zpsnqxffgvk.j
Oil temp sender (and adapter) installed.
Last Whaler ride of the year. Always a solemn time.
IMG_20151107_105115239_HDR_zpszjjyg0nr.j
But it is time to make some improvements. The mahogany needs some attention, and I have a few modifications in mind.... So I have spent the last day pulling the boat apart.
IMG_20151115_161029379_HDR_zpsrbnchqyx.j
So this will be a fun winter side project. Not that any of you care, though...boats and such.  :P
I digress...
Looking good :)
Thanks Kurk!
Been busy at the shop, so I've fallen behind with my Z stuff....
That said, I finally made the revised insert for the V2 console.
It's got a couple flaws, but for the first one, and being that it is for my car, it will suffice. There's always a learning curve.
Laid up
Freshly popped
IMG_20151119_133339932_HDR_zpsozmah8uf.j
Trimmed
Mock fit
This keeps me emotionally motivated to finish my dash.
The plug is close. So so close.
Because it would be physically impossible to have the twill weave pattern behave, while asking it to conform to really tight corners, and spaces.
The first console I ever made was one piece. A quick look back as to the quality of that will answer your question.
You'll even see that on the FuguZ. Even they didn't make the storage compartment exposed carbon, it's blacked off.
I wanted to have the piece be entirely visible carbon. Making the inserts separately allows for more customization, and simpler layups.
If that makes sense.
Edited by OldAndyAndTheSea
it totally makes sense.  I've read all the posts, but I didn't remember everything.  I do remember issues you had with the front insert...
I'm with you about the customization.   you want to be able to set it up however you want.
the tray you just made is really nice, but have you considered making a cover that can serve as a elbow-rest, kindof like the 280zxs?
s.
Decided to powder coat my finned cover.
It was painted, by the previous owner, with some nice high quality paint. I almost left it, but the only way to be certain there aren't any hairline cracks in the aluminum is to clean away any coatings.
So I blasted, inspected, and subsequently powder coated the cover its new color - machine gray. The contrast with the black is going to be nice.
As I bought it.
Stripped.
IMG_20151129_151518572_HDR_zps7h5rnyu5.j
Gray.
I can dig it.
Thanks so much! Trying to do it "right".
 ....a little composites progress.
IMG_20151202_144802190_HDR_zpsyr1qcrm0.j
Hand laid the first couple layers (or "skin coat") of 6oz fiberglass onto the mold's surface coat. Ugh, I HATE hand layup.
IMG_20151202_180522379_HDR_zpsotthnbds.j
IMG_20151202_182122078_HDR_zps2sf402dm.j
If you'll recall, a couple months ago I claimed that I would eventually make a classier cover for my distributor.
We'll I finally took the time to make that plug.
Terrible picture for those that don't remember...Here's the current setup.
Blah blah
Yada yada
A little more work, and it will be ready to mold.
A couple more days, then the mold(s) should be done - if all goes well, that is. :)
So I finished the mold today. I hand laid the remaining layers of glass, and used some carbon to beef up key areas.
Since it had been longer than 24 hours since I laid the "skin coat" I thoroughly scuffed the surface, in order to promote adhesion. Cured epoxy leaves excess amines on the surface, known as "Blush/Amine blush" - this often leads to failed bonds, if the work surface isn't thoroughly prepped.
IMG_20151204_155247566_HDR_zpsqhd1mypv.j
And awaiting cure..
Monday I will see if the mold was a success. Please. Please. Please.
Hopefully my time was well spent.
Hurry up and wait.
Update: YAAAAS!!!!!!!!
Mold turned out beautifully. Pulled so easy. You can compare to the first, flange-less, mold in the background. This is going to be much simpler.
IMG_20151207_170854194_HDR_zpshbz0qg10.j
IMG_20151207_170709011_HDR_zps48brvnzj.j
Plug survived, unscathed.
Applied the release before I left.
Sealer on the left (FMS) and the release agent on the right.
Some cool stuff is about to happen....hopefully :D
Looks awesome, can't wait to see how the dash turns out!
Thanks! Hopefully will have some result this week.
Finally was able to put some time in tonight. It's long overdue.
IMG_20151213_180941397_HDR_zpshjrdgzrj.j
The rear differential is just about ready to install. I just need to decide if I want to do anything in the rear of the car, work wise, before I install it, as it takes up a fair amount of space.
Also need to purchase slightly shorter bolts than what are pictured. They are excessive, I just wanted to see if everything would go together correctly.
IMG_20151213_195806539_HDR_zps2gh5jte8.j
IMG_20151213_195445581_HDR_zps3utgylcg.j
IMG_20151213_194046656_HDR_zpscy7io9cw.j
IMG_20151213_195559989_HDR_zpse6tobidn.j
It did. Great!
I need to sit down and order the next few parts to keep the project moving forward.
With the Holidays and such, I've been neglecting my duties.
