Hi guys, "new" to the forum (I've observed for a few years as a guest, never posted).
I have a squealing problem!!
I've had my car about 5 years. The problem started the first winter after I bought it- during startup there would be  a horrible loud, ear-pounding scream coming from under the hood every few mornings. Any slight tap on the gas pedal, problem was gone. As soon as the winter passed the problem went away. Came back the year later, gathered up my money and had all the belts replaced (and plugs, wires, timing belt, etc etc). The next winter, the problem came back, but it was daily for about a month- same thing, tap the gas and we're good to go. Had a few mechanic buddies look at it over the summer, belts were re-adjusted, no fix.
This year, the problem started before the temp even dropped. Every morning, horrible squeal. If the squeal starts right away, sometimes turning on the A/C or headlights, or steering back and forth quickly makes the squeal stop (so does getting the RPMs up above 4k). If it Doesn't squeal on startup, it Does the second i turn on my A/C or headlights.
My lights never dim, voltage never drops, and the A/C never stops working when the squealing persists. This last month, sometimes if I go through a large puddle of water it starts back up. I had someone recc'd soaping my belts- worked for 2 days. I've tried belt squeal remover- an entire can works for maybe 2 days. The last few weeks, sometimes after driving a long highway distance the squealing will start up out of nowhere (after an hour of no problems). The last few days, while driving in city traffic during cold weather, the squealing is next to impossible to stop unless I take the car out of gear and floor it to 4-5k. That usually fixes it for good, unless I turn on the A/C.
As you could guess I'm no mechanic; but I did try removing the belt from the A/C condenser- did not fix the problem. The alternator tests fine and was replaced about 1 month before I bought it (I kept the same mechanic as the original owner, until I moved).
I've been reading through the forums; I'm starting to suspect that it might be my fan clutch. I've Never had an overheating problem, though- car only hit above the halfway mark Once, driving in stop-and-go traffic with the A/C on max and the temp at 110 (TX summers are great). But from what I've read, that isn't to say that my fan clutch is fully functional...
At this point, any ideas are appreciated. Unfortunately I don't have the know-how/equipment/another car to be able to tear my car apart as much as I'd like, nor do I have the time or money for a half-*** mechanic (who has never even heard of my car's model) to try and fix the issue.
Thanks!
