jonus079
About jonus079
- Birthday 09/02/1984
jonus079's Achievements
10
the turbo is coming along (pictures)
jonus079 replied to jonus079's topic in Gen III & IV Chevy V8Z Tech Board
i just realized this is in the wrongs section. It should be in the gen 3+ section. woops -
things have changed big time. you guys may have see my other posts but heres what i decided to do. I went and took the complete rear subframe/suspension from a 2003 Lexus is300. Its good to know i will never have to worry about the rear end giving out. I also went with the front suspension from a Lexus sc400/ Toyota mark 4 supra, so i ended up cutting out all the work i did with the custom motor mounts. I did get all the floors done and I'd like to have the car painted by March. -
heres how mine worked out it a 5.3l with 5.3l accessories but it has an ls1 intake.
SC300 Suspension???
jonus079 replied to JustinOlson's topic in Brakes, Wheels, Suspension and Chassis
it an 8 inch wide wheel. well i think the car should feel more planted at cruising at high speeds and when cornering however this is all theoretical. i am sure the factory sc400/sc300 brakes will be a huge improvement over the factory 240z brakes and likely as good as the expensive after market brakes for the 240z. it surprising how thick these rotors are. i was also playing with the idea of using the abs from the sc300 but im not sure it will be worth it. haven't decided what flares im going to use yet but the zg flares are looking good. i really didn't want to use any flares but between the sc400 front end and the is300 rear end there really no opinion for that. to be honest i cant remember lol. i narrowed it at the beginning of the summer then i didn't touch the car until about three weeks ago. i think it was about 3-4 inches. -
SC300 Suspension???
here is mine so far (what a mess that garage is). looks like i will need flares. i looks like the camber is off but its really not. i just cant bolt down the wheels tight cause i dont have the right lug nuts. keep in mind its also set for the middle setting so i can take away or add camber. -
funny you ask because after not so much as going in my garage for the past three months, just 4 days ago i started working on it again. here some pictures i took today. now that summer is over ill be doing alot more work on the car in the coming months. ill keep you guys posted. here are the rear supports firmly welded to the cars frame and the overall cradle mounted to the car im hoping to finish up the welding the rear before the end of the week. i have alot of work still to do to the front. id like to have the car right side up in another couple weeks so i can start the body work. -Marcus
from what ive seen the automatics have 3.909. ill open my differential some time and check. ether way since im running a t56, i should be doing 80mph at about 2.2k rpm in top gear.
here are a few better pictures. still waiting for argon to weld. if you would like to see larger pictures click on the link in my sig. the shock should fit with no problems
Thanks for the positive feedback! unfortunately this rear end doesn't have an lsd diff but at $260 for the entire setup, i can hardly complain. It looks like there are a few after market company's that make lsd's for around $700-$1200. I dont know much about the front suspension on the is300. The one i pulled the rear out of had the front pretty much cut off from an accident so i couldn't really get a good look at it. BRAAP: I didn't realize the 300zx also had a cradle. I never really looked into it. I'm glad to hear someone agrees with me about the rear end especially with all the diagrams, observations, and facts you illustrated. Up until now it was pretty much theories in my head. I'm hoping to get a lot more work done Tuesday and Wednesday. I will post more pictures with the car flipped over so you can better see how im connecting it to the unibody.
i dont know much about the 300zx rear but its my understanding that its not modular, that is the control arm connect into the body. the only 240sx rear ends i could find had 4 lugs which i wanted to get away from. not only that but i was never really impressed by the geometry of that set up. it just doesn't look like the best design to me when compared to is300 rear end. the only reason why i was even considering the sc300/400 rear end is because i'm using the front end. ive seen people put alot of power through the is300 rear end and it appears to be very sturdy. anyway i did alittle cutting and got it roughed in today. it looks pretty good. unfortunately my tig welder is out of argon and i cant get anymore until Tuesday so i guess it will just sit there until then. i really wish i had a wheel to test fit.
so after alot of thinking and research i had my list narrowed down to two rear ends: lexus is300 and lexus sc400/300. well today i went ahead and pulled the complete rear end out of a 2004 lexus is300. in the end i choose it because the sc300 was so much wider (about 6 inches). ive also seen people put huge numbers down through the is300 rear end with supra engines. i mached it up and it looks pretty damn good. there is about an inch from the hub to the outside of the rear fender so it looks like ill be running small flares. i dont mind this but i really want to use the smallest flares possible. tomorrow i plan on putting the cars back on the rotisserie to get a better idea of how it will come together. just thought i would share some pictures.
SC300 Suspension???
im also using the rear end. from what ive seen the suspension is identical to the mkIV supra. The only diffrence i could see is that the supra has larger cooling fins on the differential cover. the control arms/ subframes seem to be the same. -
SC300 Suspension???
i dont plan on adding any flares. -
SC300 Suspension???
I got it from a friend's junk yard and he game me a deal that i can publicly announce. But I could use my insider status and get another with everything pictured for around $400, $450 with both struts. -
SC300 Suspension???
yea they are. i was looking at a couple at the junkyard yesterday and they are the same. i ended up picking one out of a sc400. anyone else know of someone doing this swap or completed it?
