Kooneon
Everything posted by Kooneon
  1. got a 260z with the spare tire well cut out. Can i still use the stock gas tank and will it bolt up fine as long as i have the straps?
  2. i talked to mike this morning and after debating with him for about 10 minutes, we realized that the reason he said that the arizona z manifold cant be used is because he was talking about a draw-thru setup. I am going blow thru and running an intercooler and blow off valve. (looks, sound and performance) If you go blow-thru might cost you a little more but it will be what you want. At least i think so. seems safer too. And just for the sake of saying it... Mike Z said he's been around plenty of blow-thru Z setups and even has had one. They're actually on his favorites list. Thought i'd say it cause a lot of people hate on the blow-thru setup, but thought i'd say. Hope that it helps with what you are trying to do.
  3. If Mike Z can let you know why it would not work, that would be helpful because I am under the influence that it would.
  4. I actually posted this thread this year! DONT KNOW WHY IT SAYS 2005
  5. Thanks Zredbaron. Thats the type of info i was looking for.
  6. EDIT--Deleted part of post as it was flaming other members. Please, give answers to this question so we can turn this thread back into what it was intended to be... helpful.
  7. i plan on running the arizona z manifold. why do you ask?
  8. I am doing a blow thru setup on my 260z. I plan on going with the holley style carb setup to make running this setup easier. I also will be using a turbo prepped Demon 650cfm carb, so fuel isnt a problem. I was wondering what turbo i should use. I want it to mount up as easy as possible. Spooling isnt an issue, i'd prefer 3000 rpm range for spool not peak boost. let me know what you guys think.
  9. while at work today, i thought about the setup on the devil z in wangan midnight the series. I was wondering what it would take to run this setup being that i would have to fabricate parts. I also pulled an idea of triple turbos. why wouldnt this work? give me all your opinions on this one! Be supportive not full of that bull****!
  10. Does anyone know the lowest horsepower rating for the 3.1 stroker motor?
  11. My speedo and tach dont register. the needle doesnt jump or anything. the strange thing about it is that the brake light come on. can anyone help me.
