ok so the car is still not staying on due to injectors not spraying, i changed fuel pump, fuel tank w/ sending unit, fuel rail, injectors and ecu ( all good used parts).
I have two set's of stock injectors, i installed them both and nothing. (i know its not the injectors or could bad luck run that high!!)
I did get the ecu out of a non running car. maybe that ecu was bad i dont know!!
if i spray starting fluid it will turn on and stay on while maintainin spraying..it will rev and all..but as oon as i let the spray go it die's
Im starting to think is wiring problems or somthing the guy i bout it from did say he had taken it to a michanic and he said it was an electric proplem
the guy didnt believe him so he never fixed it..i checked the all wiring and cant find a problem...
I anybody has any ideas let a brotha know...thanks guys
