jturbo06
Everything posted by jturbo06
  1. Whats a fair price for the set running with 100k ish miles?
  2. fisrt off im sorry to ask this im sure its been asked a bunch befor but ive been searching for the past 2 weeks trying to find a wiring diagram for a rb20det but im having no luck, i got a pinout for the ecu and evey link for a diagram ive found doesnt go anywhere anymore.... i apprecate any help anyone can give
  3. so i dont have a scope but i tool my volt meter dont know if it will work but i cant fig out where in the fsm it tells me where to prob so i did a cont test to find the wires for the dis and ignitor to the ecu, found 2 of the 4 from the dist have 5 volts with the key on 1 has 12 volts and 1 has nothing , the ignitor wire isnt gettign anything so does that me my break is in that wire? thanks guys
  4. well then im just completly stumped why im not getting any spark at the coil
  5. i thought the 81 only had a signal every 4 degrees and the 82-83 and one for every degree
  6. i have it but i cant get it to work ive narrowed everything else down is there a trick to it or something?
  7. im just trying to get it running for now, can it work with this dizzy or do i need to get the original sensor? also how much would you want for it
  8. i just bought a 81 turbo auto for 400 bucks, from what ive been reading this year has the cas on the crank pully, mine has the ring but no sensor but i do have one in my distributor, im thinking the previous owner tried to swap it? (car came with a distrubuter without the cas in the back) is it possible to get this setup to work?
  9. ive been going over the diagrams and im still confused, anyone got a pic of the wires or somethingk that can help me out?
  10. well i grounded the coil wire that goes the the dizzy to check for spark and there isnt anything
  11. new to forum i just bought my first 280zx for 400 its a 81 turbo auto, 2 things the car doesnt start theres no spark at the coil but theres voltage, the bracket thingy with the wires i cant remember what its called is new, good grounds i added 2 new ones 1 to the block and one to the body, coils new and ecu is good injectors fire and green led on ecu os wtf? anyho i also have 3 connectors under the steering wheel loose heres some pics someone please help my fiance wont stop complaining at me for buying another car that doesnt run!!!
