350zdriver
Everything posted by 350zdriver
  1. 350zdriver
    Rat Z Panel
    Yea I figured that it was going to be a trial and error process because I will also have switches running everything. I DO NOT want my turning signals as switches tho. I am going to get a universal turning switch for the steering column but other that that everything will be on toggle. I should go through the trouble of resizing some pics for you guys to see.
  2. But then I guess that what I said had nothing to do with what you asked
  3. I have a buddy that works for nissan in Houston. I wondered what my diff was on my 79 280zx. He got me in contact with a parts manager who looked up my car by year, model, and trans. He told me I had a r200 and told me as far as ratio I would have to find that myself. Believe it or not, not every 79 280zx manual trans has the same ratio. At least thats what he told me. So i would assume that any1 wondering what there diff was should try calling their local Nissan Plant (not dealership) and ask. They MIGHT be able to help you. As far as ur ratio take your diff cover off mark a tooth on ur pinion gear and start counting teeth as ur spin ur wheel to count them all. Then count the teeth on ur ring gear the same and divide the bigger number into the smaller number to get a 3. or 4. something. Thats ur ratio. I'm sure most of you know this already but if not here is the way to find it for sure. Also I believe that if you look at ur diff the cover will be a circle for the R200 and more like a rectangle with rounded corners for the R180. I hope this helps someone and GL.
  4. 350zdriver
    Rat Z Panel
    Also I could use some advise for headlights and tail lights wireing if you have the time.
  5. 350zdriver
    Rat Z Panel
    Way to go man that looks really good. A little big and bulky for my taste. This is your car tho brother so U rock it the way you want. I also have stripped my interior and wireing harness along with AC stuff for weight but im dropping in a 350 and moving the battery to the rear for 50/50 weight. My buddy has been tryin to talk me into an aluminum dash . Again GOOD JOB.
  6. Ok so this link has been down for awhile now so I'll "Bump" it. Any progress on the front and rear? Would really like the rear and probably the front. If you are not doing this anymore let me know a few things so I can get this goin on mine lol
