I'm thinking that's going to be my best option for hood clearance. This still won't solve my oil pan problem, but would fix my problem with the hood. I'm sure it will look noticeable to me, but hopefully you're right and nobody else will know the difference.
I'm not sure how much I can modify the front sump, because that is where the oil pump is. It is driven off of the distributor, so that's why it's up there. When Ford came out with the Fox-body cars, they needed a rear sump, so they just made a dual sump pan. Only the rear sump is actually a sump. The front one is strictly for oil pump clearance. As far as I know, the oil pump isn't any different than the 5.0 unit, except for the bigger input shaft, so maybe I can cut/bend the front sump to clear. Anybody done this?
