Rising Sun Performance
Everything posted by Rising Sun Performance
  1. Hey , Based on your pics of this engine ,of course it was rebuilt .These pistons are aftermarket and Not Nissan OEM items ,based on the balancing pads .Your crank measurement seems odd or did you mean .0007 (7 ten thousands ?).If you want a correctly built engine trust the machine shop to measure the bores for roundness and taper .Anything less than perfect ,and your engine will Never be perfect .I boils down to what you want and expect from this engine / car when finished .If your alright with it burning some oil ie., quart every 1000 miles ,or do you want it to not burn a drop between changes ? Maybe a new set of .020 pistons fitted or maybe have to go to .030 in aftermarket pistons again or get factory .040 ( Nissan only offered pistons in .020 increments )to have a perfect piston clearance (Rather tight at .001) .Use factory rings ,NPR ,or Total Seal for the best ring seal.Do Not use Cheap cast Rings .The crank probably needs to be turned .010 /.010 is your measurement is in anywhere in the ball park . You didn't mention the head condition ,but you Must have New intake seats installed (Steel ) if it still has the stock brass junk ,set up with the correct valve stem heights ,all equalized . Good Luck , Steve www.risingsunperformance.com
  2. Hey , I have both New and used in stock . Let me know if you have already bought them . Steve
  3. Hey , First off ,I don't have one to copy and second ,The channel numbers are on a clear plastic insert on it . If I get too despret, I may take you up to get someting . Thanks, Steve
  4. I'm looking for a Factory AM Radio for a 70-71 240 Z . I need the Faceplate as I have a Radio and switch ,but will buy a complete unit if you don't have an extra faceplate .I can pay with Funds of your asking ,ie. PayPal ,Money Order,etc. Thanks !
  5. 1970 - 1971 first series 240 Z interior parts needed or recommended sources for them . I need NOS New or as close to perfect used parts as possible. Pics and prices please .Ship to 76126 . 1.Ashtray assembly 2.Stock radio with face plate . 3.Rear deck lid inside plastic panel(black).Must not have any broken corners . 4.Glove box cardboard . 5.Door panels(Black). Must be very good with perfect chrome strip .New panels must be for a US spec car. 6.Seat cores with knob tilt adjusters. 7.Complete seat belt assembly
