3200turboz
Everything posted by 3200turboz
  1. thanks i will take pics as i progress on this project. it will be a couple of weeks befrore i start. I have to get the car on the lift to do this. i have found i guy in Sidney who has done this swap and am getting info from him.
  2. The reason i want to do the sub frame is I am using a RB25det and want the body as strong as possible so i don't get any twist in the frame. by using the the subframe it ties the rear diff torque to the out side frame rails. then when i add the roll bar it will tie in at the same mount. this is not that big a deal. Plus I am going to use the z32 front suspension and add ABS to this car. I want a modern suspension and stay Nissan.
  3. I am about to try to install a complete 1996 rear suspension into my 78 z anyone know if this has been tried before. I know it will fit inside the wheel wells and looks good for mounting points, hust thought I would put this out there before I get started. I also want to do the same for the front.
  4. you will have no problem fitting into the 260z. I really like the early 260z built in ac a better console easier to work on dash.
  5. I had a Z shop back in the 80 in turbo Toms hay day. His cars where very fast but also just as unreliable. Talk with some of the supercharge MFG and get advice from them and also talk with Holley. They will be your best for info.
