TheSwede
Everything posted by TheSwede
Bloody hell I´ve been missing out on alot here...hehe. Sorry guys, new apartment, new job and a carcrash kinda kept me busy the past weeks... (watch out for yellow semis coming up behind you at redlights...) Timz, amazed with your work. Didnt think anybody would jump on the idea that fast and try it....actually thought I would beat u to it. Please keep us updated.... Worst part is that I dont have much to add at the moment... Timz and Tony D has really kept this thread vibrant. (And as always, exuse my bad english.)
While discussing oil flow and pressure.... I good buddy of mine has a Toyota Celica think its a 76....or some like that...and he´s a frequent drag/trackday driver. The engine is from a Toyota Hiace, a 2.6liter straight four. Turbo converted with oil jets from BMW,the type you machine into your maincap bearings. Not much else done internally than forged pistons and rods. The last dyno sheet said 627bhp at the wheels. (2 bar/30psi of boost Stock oilpump by the way. So what im trying to say is that the jets must be a good way of extracting heat via the bottom of the crown without stressing the water based cooling system... which at thoose levels allready are taking care of alot. So with the oiljets and an oilcooler you have a second system to extract the cylinder heat. Still not saying that coating is bad... but as I see it you need a good cylinderhead/gasket if you make the temperature stay in the top of the engine. And another thing is..... when the coating has worn of you need to recoat them. The oil is easy to change... plus you can easily see if its time to change.... not as easy with the coating. Then we have the topic of too much oil on the cylinder walls.... The jets, as they should work, will not put extra oil on the cylinder walls. Its a directed spray via a valve at higher oil pressuers...the picture is a bottom of a Saab 9000 engine.... damm best turbo engine ever build... And as usual.... exuse my bad english.... hehe
Here´s a link to spice it up a bit.... http://www.turbo-mini.com/44648/23109.html
Well as john said a coating on top of a forged piston.....while this could be a good way to make your stock pistons a bit safer at a lower cost. As I said before.... they come stock on modern turbo engines for a reason.
Jupp.... I´ll have a look at it. Just give me a day or to... a buddy of mine has a company that only works with the Saab engines. And if you could take one of thoose scrap blocks and put a drill to... it would be great. Since there just aint no scrap blocks laying arround in this country.... hehe.
Well coating in all its glory... But there must be a reason to why all car builders with good performance turbo engines use them....instead of coating. (Cost and logetivity) Dont know what the cost for coating is around here.... but I bet building oil jets will be cheaper. The ones from BMW is about 14 us dollars a piece (in sweden) times 6.... and the machining.... cant be that much. (Get back to you on that)
Well as the title says..... Has anybody put cooling jets for the pistons in there L28 engine.... like the types in BMW,Saab,Volvo,newer Nissan turbo engines. Its just a thought... considering that the ones from SAAB or BMW comes at no cost at all. (Well at least if live in Sweden). Thinking about doing a turbo conversion....and it whould be a good way to keep the pistons a little bit cooler. But it does require drilling and tapping the enigne block if you use the type from Saab or drilling and tapping the main bearing cap if you use the type from BMW. Most types of oil jet has a valve that opens att a certain pressure, but the question is if the oilpump/flow will be up to the task... so you dont loose the much oil at other areas when they open. And where to drill.... would suck to hit the water areas of the block instead of the oil mains...hehehe Any ideas, previous experiences....? Cheers
Hi.... Could need som help....again...hehe. Could you guys have a look on the pictures below and tell me where the hell my front airdamm and wing comes from. Would kinda like to have sideskirts to match it... Cheers.... /Swede
Yeah... Been thinking about it the last couple of weeks.... and as you put it, option 1 sounds like the best way to do it. But.... little bit worried valve springs, valve lashes and all thoose little things in the engine head.
Ok... but did you run a stand alone efi or stock? I got a good swedish made system on the shelf, but i dont wanna use it for that car. Its a cruiser....no point of building a 2500$ system in it. : )
Yeah.... im kinda thinking about it...hehe. But dont get me wrong, it works... as soon as you reach about 4500rpm....then the bat out hell finally finds his way out of hell...but theres not much happening below thoose revs. And what bugs me most is that it certenly dont feel like your driving a 2,8 liter engine... more like something in the 1,2 litre range... : )
OK...Here´s the deal... bought the car about a year and a half ago, runs good but idles kinda funny from time to time. Hehe. By the way its a 2080zx -81. After intense investigation it turns out that the previous owner had installed at Schneider 270/280 duration camshaft in it. And it´s all stock EFI, the only thing the guy had done was to make a latch in the distributor, so he could adjust the ignition a bit further.... Further more I have no idea if the valve springs, lashpads or rockerarms are the proper stuff or just stock. I´m pretty certain the only thing he did was to change the cam. So what to do.... Is there a good simple way to make the stock EFI feel some love for the camshaft... (and i dont wanna know what the AFR/ignition values has been) Or should i just drive the crap out of it, it worked last summer, and start rebuilding my spare engine? Cheers from sweden once again.... P-J
Speaking of the non turbo block... whats the difference? Does the turbo block have "oil squirters" for the bottom of the pistons?
Thanks for the input guys... Can imagnine im far from the first to ask the question about 300hp turbo... But since my forum searching skills are far from perfect, I just became the last wave of space invaders to bug you guys... Thnaks again. PJ
ah..... now its starting to sound a little more close to the real world. hehe Perfect, cause my plan was to use my Nira I3+ ecu, a proper intercooler in the front, with all the little gizmos from saab when it comes to fuel injectors and such....they work real well with the ecu u see. Down below is a link to some pics from my latest project, its in swedish but just klick the pictures down in the right corner of the page, thats the sucker who ended upp with 400bhp ... a nissan 200sx with a saab 2.3t engine and a opel omega tranny.. so u guys can see the whiskey induced madness i´m in... http://www.garaget.org/mypage/gallery.php?user=88383&album=12958 Cheers /P-J PS: By the way, the person soldering the cables for the Ecu in the pics is my old lady Emma....love her from the bottom of my crankshaft heart..hehe
Thanks for the input johnc... And ill be checking that book out from wizard, when its realesad here in sweden... semptember i think. BTW...A stock L28et produces 200bhp right? But at wich boost level.... about 0.6-0.7 bar or some like that. (10psi kinda) Bloody he%&, my last build were a 400bhp saab 9000 2.3t on stock internals and without any head work. But ok, thoose engines are like 20 years younger and known for there ability to take abuse. cheers
Hi...and hello. Sitting here contemplating the coming winters engine build. First up a question for all you americanos.... whats the octane ratings on your pump gas? The reason why I´m asking is a discussion some months ago on this forum, about me building an L28 turbo engine with aprox 300 crank hp without water/methanol injection. The answer i got was that the for example p90 head had combustion chambers that was supposed to lower Nox emissions, and beacause of that they are prone to pre ignition and knock. Not that I really have that one figured out yet, since Nox is created from high compression and high cylinder temperatures, actually thoose heads shouldnt be that bad. Well well... Ok, now back to the question about the pump gas. Cause i kinda have an idea. The soup you can buy at the stations here are 95,98 octane gasoline and E85 wich is ethanol, about 107 in actane rating. Using the E85 would keep my pretty much on the safe side.... that along with a aftermarket ecu system, intercooler and so on. Thought and ideas anybody? /PJ PS: And as always when im writing in english, please excuse my spelling.
Godkväll... (good evning, in swedish) Got this question for ya... how come people use water/meth injection.... Been searching for some time and cant get a good enogh answer. Yeah I know the benefits, but is there really a need for it on the old L28et...when you are looking for about 350 engine hp. And setup containing Intercooler, Nira ecu, and all the modern tech stuff. Like come on, they cant be that crappy even being 30+ years old. Cheers.... PS: For all of you that dont know what Nira is.... http://www.niramotorsport.com/ the swedish way to make your engine run... hehe
All problems solved.... As i said they gave me the wrong plugs..... and after making em give me a set of new ones, same as the ones the car had when i bought it, it works just perfectly. Its not the stock plugs, but as it turns out my ruff idle is beacause of the 280/290 cam the previous owner had installed....hehe. So to be honest with ya, the plugs i got might not be the right ones but the car runs and thats all im looking for this summer....Got plans for the old Z this winter. Thanks for all the input. P-J
