stiness101
Everything posted by stiness101
  1. @1 tuff z, its a 73 with roundtop's on it @zentech, sent you a pm
  2. Looking for the throttle linkage for a 240z from the firewall to the dual SU carb's. Attached is a pic highlighting the part. Let me know what you have, thanks!
  3. Hey Guys, When I had the pan off, i checked the pickup and the screen was not smashed and everything was tight. there wasn't any holes in the welds or brazing either. For length, it is really if I'm just accelerating hard through about 3 gears. I guess it could make sense since it seems to drop in say, the end of 2nd gear going into third that it could be possibly sucking up all the oil. I could try overfilling it a little bit, about how much can i go before it causes any windage issues? An accusump would be nice but I dunno, i don't really want to put it on the car since its just a street car.
  4. Hey guys, So when the engine revs out to 6-7k, the oil pressure drops. It does not go to zero, but my guess it it loses about 10-15psi. I've replaced the oil pressure sensor with the same results. I was wondering if maybe there was some sort of cavitation issue with the oil pump failing at high RPM. Oil level is full so I dont believe its running out of oil. A little bit of history behind the motor - it hadn't been run in years before I installed it. It is somewhat built L28, flat top pistons, e31 head, bored out to 2.9l. I am running 10-30w castrol syntec now but will be switching to amsoil next change. When i installed the engine i pulled the pan off and made sure there was no issue with the pickup and everything looked fine. I plan to hook up an external pressure gauge besides the stock one just to check and make sure its not the gauge but just wanted to see if anyone else has had this issue? Thanks.
  5. Hey, I was looking for a good 1980 280zx 5speed transmission. Will consider other years but really wanted the good 5th gear ratio from the 1980. Also, will consider competition spec 5speed with close ratio and overdrive 5th. let me know what you have in a P.M with a price and location, thanks!
  6. Hey, Looking to see if anyone wants to sell their STI R180 adapters made by Beta Motorsports. If so send me a PM, thanks!
  7. Hey, Looking for a working 3 wire tachometer for my 240z. If you have one for sale please let me know with a price shipped to 93105, thanks!
  8. Hey guys, So I've been adjusting the float levels on my 4screw SU's trying to get them to be where there supposed to be. I just rebuilt the carbs with ztherapy's kit and cleaned everything but the float levels are way to low. I was using a measurement tool of 9/16's to check when the valves were closing off. The floats do still float in the fuel and the car runs only when the choke is fully on cause thats the only time it can suck up the fuel. Any other ideas of what would need to be adjusted? There is one spacer/gasket where the valve screws into the top of the float bowl, would taking that out make a difference at all? Any help would be great as I'm kinda stumped.
  9. Hey Guys, looking for a heatshield for my round tops so lemme know if you have one with a price. Id really like to pick one up before this weekend so local pickup preferred (Santa Barbara, Ca), but not necessary.
  10. thanks for the pics, i think its the same car, the pic i posted might just be a newer pic of the car.
  11. Yea, if you have more pics of it, could u pls post them up? I've tried looking for more pics of the car but can't find any.
  12. And does anyone know of any more pictures/info on it? I found a picture of it a long time ago and has been my desktop pic ever since, but i cant find the original picture. thanks for any help.
