Hello I just want to clarify some things on the rb swap. I was shocked as to how easy swapping the motor was into the z. Ive done a dozen rb swaps into 240sx but never in a Z until this past weekend. It is basically the same, but the 240sx you swap out the crossmember and the z you swap the oil pan. So here is a outline of what we had to do.
The car is my friends 280z and the motor is a rb20det out of a 93 skyline. So first we took the l28 out and cleaned up the engine bay a bit, then changed the oil pan to a rear sump. Then we grinded down the nipples on the stock rb20 mounts as they are on opposite sides. Then we put the engine in. We used the stock Z trans mount and bolted it up to the rb tranny. Then we bolted every thing up. Then zizwheeled the cover plate off the input shaft, and bolted up the drive shaft. That was it. It sits in there just like one in a 240sx with the shifter forward one inch. So after that it was just fluids, fuel pump, wiring and a throttle cable from a 240sx. It took about 10hrs from start to finish.
After seeing how simple it was, I have decided on getting an rb25 for my newly acquired 240z (hence Im a newbe). I will use a rb20 trans and mounts just out of simplicity and a weekend of down time. I would keep the rb25 tranny around just incase I keep braking the rb20/ca/ka/sr tranny’s. But I think it will hold up just fine at 400hp. Same goes with the rb26, but the main bitch part with those is the whole oil pickup part. I had a rb26 240sx where I used rb20 mounts and a rb25de trans which is the same thing as a rb20det trans, and it bolted up just the same as any other rb. The tranny held up even after 460rwhp so Im just going to go with that. Anyways, I don’t know if what I said has already been covered but I figured I would share. Hopefully I'm not just wasting bandwidth.
Snail
