I think there was one wire that was not the same colors as the S1 stuff, but I was able to trace it down to the ECU and verify the the Pin #. Do you know which wire it was?
The Cas Gear is good i even spun it by hand no pulse.
I measured the out put on 0 degree voltage does not change from 2.3 volts
on 180 Degree it measures 9mV.
I think the Cas may be at fault because FSM says its supposed to be between 2-3 v
I swapped out relay to my fuel pump and they all work
Does anybody have the proper pinout to get the s2 power and ground points?
I appreciate u guys responding back
