destro79
  • Gender
    Not Telling
  • Location
    billings, Montana
destro79's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
0
  1. It could be residual oil, from the block or the cylinder head bolts, that is my guess since there is not much indication where you exactly see the oil and do not know what you have whether it be rebuilding the whole motor or just installing a new head, if i was to take a guess it should be fine as long as you torque everything to spec.,
  2. ok looking at ms3 setups, want to control as much as possible with ms3 have gm iat and ect sensor and map daddy 4 sensor from diyauto tune, looking at getting a board that needs assemblying option #1 http://www.diyautotune.com/catalog/ms330k-kit-with-mapdaddy4-upgrade-p-514.html or option #2 which im leaning towards http://www.diyautotune.com/catalog/megasquirtiii-wpcb-v30-unassembled-kit-with-black-case-p-419.html maybe even an assembled units option #3 http://www.diyautotune.com/catalog/megasquirtiii-ems-system-v357-assembled-unit-black-case-p-420.html or option #4 which will be leaning towards in the assembled direstion http://www.diyautotune.com/catalog/megasquirtiii-ems-system-with-ms3x-expansion-v357-assembled-p-435.html and will be looking at somehow putting a cam sensor in
  3. Ok tb spacer ordered now i need a tb from a 240sx pls help ty
  4. Pls pm if you have one for sale, ty
  5. First I would like to thank everyone for helping me out, i am in the midst of gathering all the parts i need for the basic turbo swap just to get it moving on the road, any and all links you guys supply to help with info will be read carefully, i am the midst of looking for injectors, i will be eventually getting a megasquirt system, i will be using a stock 81 turbo with n42 intake bored out to 60mm and 240sx tb, with a p79 cylinderhead with a stock cam, i plan on using the supra 440cc injectors but was wondering if anyone is using a resistor pack for they can create some heat? and my second question is if anyone knows where to get the 240sx tb adapter plate with a port designed into it for a possible cold start and/or map sensor
  6. its OK that is why i am trying to find as much info as i can to help decide what the best path i should take before i get anymore parts for spark and timing control.
  7. so if i read your reply correctly it would be easier to install a turbo 82-83 dizzy instead of getting the 81 components i still need, (and also from what i read from continuing to read the rest of the forum)
  8. found this posted by cgsheen But, straighten this out first: - You have a 1981 L28ET? (1981 280ZX Turbo engine) - Is has the EXTERNAL Crank Angle Sensor bolted to the front drivers side of the engine and wiring that goes up between the dizzy and t-stat housing (round 4-prong connector)? - Your ECCS (ECU-to-engine) harness is from a 1981 280ZXT and it has a dropping resistor pack? - Your ECU is from a 1981 280ZXT? - Are you sure the oil pump is stock 1981? (since the dizzy isn't there, post a picture of the "hole" it goes in - to make sure someone else hasn't already modded the engine to accept an '82-'83 distributor) If it's ALL stock 1981, then you need an '81 dizzy (which is essentially a body, cap and rotor - it doesn't do anything except distribute spark. Doesn't have any other electronics as the CAS is external and the ECU controls the Ignitor/Coil on this thread http://forums.hybridz.org/topic/108019-distributor-question-for-81-l28et/?hl=turbo+distributor&do=findComment&comment=1010381
  9. no but can take some later i had bought it from datsun_z240 last month, but when i looked at it i did not see any place for a connector on it, and i keep reading that it has a external cas that reads off the crank pulley
  10. i have read that the 81 turbo distributor doesn't have a crank sensor inside it.
  11. oil thrower? haven't heard of that part in my search yet.
  12. im just trying to find out what would be easier to do, install my 81 turbo dizzy and get a crank pulley and sensor for it, or cut my loss and by the 82-83 turbo dizzy and shaft, unless the 81 turbo shaft would work?
  13. ok ty and on the dizzy shaft for the 82-83 turbo would i have to take the front timing cover off to change the gear thats on the crankshaft or is it like plug and play?
  14. you think its possible to use the advance with the mega squirt system without locking the dizzy and have it work fine? just came to mind and hows this for disassemble and recondition? http://atlanticz.ca/zclub/techtips/distributorrebuild/index.html
  15. ok, i have been searching the forums for any thing that could help out before i get ahead of myself, no luck yet and also using google.
