nitrostamped
Everything posted by nitrostamped
  1. should I take the rear end or send it to the scrap yard?
  2. "my goal is a car I can drive to work on Fridays and be competitive at local racetracks with turns" I would like to take it to the track so with that in mind any other parts I should take to make it more competitive?
  3. What about the gas tank or from what I read I need to pick out the baffle and weld it in mine. any of the glass?
  4. " Take the rear diff, Axle shafts, and if you want to swap to rear disc brakes. Take all the rear brake components. You will need 80's maxima caliper mounting brackets. Keep both driveshafts so you know which one will fit in the 260 after the swap. ". I will should I use the suspension too or is it not worth it? You can use the zx booster, Mount it upside down. Then you can use that zx mastercylinder. Use the 260Z clutch master cylinder, ZXT 5spd, and engine of course. Do the ZX alternator upgrade swap while your at it, and install the diode so you can turn the engine off. You will find all that in the swap write up. You can use the zx radiator, You may need to drill different holes to mount it, Its a tad larger. Using the oil cooler is up to you. " Will do thank you I did a 83 ZX n/a 2.8 swap into my 260z so remember a lot of what I did. Don't be impatient and read more than you have done so far. I did research for 2 weeks before I did my swap. " Yea homework time
  5. I have a rebuilt one from a 74 that was just rebuilt 275+ shipping 90712
  6. Do I need the whole rear end or just the brakes to make that work?
  7. I have an 82 280zxt 5 speed and a 74 260z 4 speed. I want to take every “better component†from the 280zxt and put it in my 260z my goal is a car I can drive to work on Fridays and be competitive at local racetracks with turns. Is there any good information on what smaller parts I should use from the 82zxt? Examples might be use the brake booster since the 74 will not work with the turbo setup. Should I bother with the clutch master or just stay with the original one in my 260? I’m guessing I should take the radiator and oil cooler but what else should I take? Suspension brake components, rear end? The silly voice that says “lights are on� If someone just has some great links that would be helpful too I’ve been digging for a day or so and I can only see long post helping people with wiring issues.
