rayamajhia
Everything posted by rayamajhia
  1. Hello, I am new to brakes and I am try to fix my self. I have 1980 280zx non turbo. Last week when I try to bring the car out of my drive way suddenly my brakes are not working. When I apply the brakes they go all the way no pressure. Also when I pump the same thing it goes all the way and makes a sound like if there is a air leak a noise when you are pumping air into a basket ball. So any ideas where I should be looking at? I look around the week and there is no leak of oil. please let me know and Thanks in advance. ray
  2. I think its good to run a new wire for the speakers. I have 280zx 1980 non turbo 2 seater. Also if you search in this forum for manual then you can download them and if you look under electrical you can find the information on radio wires. Guys also if you could help with what is going on with my lights since i put my cd player on. Also i have taken my cd player out at this time and still the lights don't come up on dash when my headlight is on and the lights in rear and 4 light around the car they don't work. Any ideas?
  3. I also ran all my three speakers its own wire and didn't use the factory wire, I disconnected. I can get the radio to work but now since i put my CD player in to my old radio. I am having problem with my dash light. My dash light don't comeup when i turn my headlight on and also the rear lights and all four side marker light they are not working.
  4. I don't think i am getting any smoke but I see lots of black carbon stuff in the floor. When i start the car i don't look back but i need to do that as well.
  5. My car has 130k miles on it but don't know when it was replaced last time. ray
  6. I am trying to figure out what is causing my car to give like a vaccum when I start my car in cold times. Starting the car is not a problem it starts just fine. But after I start the car and the tempeture is below let's 70 or 75 then it needs to started for a while so that it will not give any vaccum noise when i give gas. If the tempeture is in 90 or 100 then it is just fine. I can start my car and drive rightaway and no problem. But if it is below 80 or then I can't just start my car and go. After I start and try to give gas then it give me noise like vaccum and doesn't rev smoothly. If i let the car sit there and warm up after 5 or 10 minutes depending on cold or warm weather it is fine. Also i get lots of black stuff (carbon i guess) in my muffler and my floor when i give gas to the car. So any suggestion would help? thanks in advance ray
  7. Can anybody please tell me how you know if your rear struts are bad or not or need replaced? thanks in advance ray
  8. Thanks so much guys. I really appreciate you guys help. I have installed it and it is working on my old spearker just fine and even better sound. I will take a picture and put it out here on what I have done. Also I kept the old antenna up and down switch and it still works. I would never change old radio but it was not working properly and the signal went off every couple of minutes and very rough sound. But i am happy with my new radio (jvc car cd with remote and mp3 player with bluetooth.) thanks again guys. ray 280zx 1980 non turbo. (very fun to drive)
  9. I think I can get this now. thanks so much when I am done I will put picuture with instruction for others. thanks again ray
  10. Thank you so much for the answer guys. But still i don't know what color would be ground ? I am looking for a black wire but the stock audio wire don't have any black wires. may be i should take a picture and post here. thanks ray
  11. but how do i know the ignition and earth then? any idea?
  12. thank you so much i will try to do that
  13. I am trying to replace factory radio to simple jvc cd player on my 280zx but i am not connecting to correct wire. I need to connect to power, ignition, and ground. the factory wire is cut off. I don't know what color is what in 280zx 1980 model car. if anybody know what color they are, i would really appreciate. or if you have link that have those information that would be great. thanks in advance. ray
  14. thanks for advice. I will try that today and post my results or updates. thanks again i really appreciate your answer. ray
  15. Hello all, I have 1980zx n/a and I am having problem with cold start and I have been reading the pervious thread and got confused. When i first my car is starts nice in cold but when I try to drive right away then it hegitates and backfire. Then either I have to let the car to warm up for 10 - 15 min and the problem is gone or i have to give like really hard rev for 10 to 15 time to get the engine to warm and the problem is gone. Other wise the problem is there. Please advice and many thanks to everybody. ray
  16. hello; Where does vaccum leak occurs and what and where should i look for? Also where does the head temp sensor located and can i replace my self? i changed my plugs my self and oil but i haven't change any sensor yet? thanks ray
  17. hello all; I have 1980 280zx non turbo. I need help on my car. My car starts just fine about after that if i want to ride my car halts and back fires. Then i have to rev the engine for a while to warm up the engine. When the engine is warm and hot then the problem is gone. Can anybody tell me what is the problem ? I am thinking of replacing my fuel filter but some body was saying i have to change sensor? I am not sure what he was talking about. If you guys can help me that would be great. Thanks in advance. ray
