robhenry2990
Everything posted by robhenry2990
  1. I am I just order the MSD-6AL 6420 and a blaster 2 coil
  2. Ok how bout this then the crane ignition system is it just plug and play? Or do I have to get something (other than a coil) to go with it?
  3. I want to upgrade the spark. I want to get rid of the ballast. Am I overlooking something? Is this setup plug and play?
  4. Haha I didn't even realize I did that lol. Its says to remove the reluctor and pickup coil. Now does it need to be replaced or just removed? I'm sorry if these are idiotic questions.
  5. I know that the is an overplayed post but after a few hours of running in circles I'm fed up with searching. I've read that the 280z has electronic ignition is this true? I thought about doing the crane ignition and coil ( http://www.thezstore.com/page/TZS/PROD/classic11g/12-4002 ) But it says it needs a different reflector wheel and pick up coil. What should I use? I also thought about doing the 28Ox E12-80 distributor with this but having a hard time finding one. Also how hard and expensive is a cop setup
  6. Yea I'm trying to figure something out. I'm thinking of going to the crane XR 700 EIS and PS 91 coil also. Any thoughts on that system
  7. So I was replacing my coil and I was screwing the mounting bracket back in and the bottom bolt snapped. Now I read that the mounting bracket needed to be grounded.can I run a wire to ground it somewhere else?
  8. I'm looking to get a set of xxr530 15x8 +20. I'm wondering if these will work on a stock 280 suspension. Also curious as to what tire size to use. I was originally going to go with the xxr 527 0 offset and 225/50/15.
