Topher
Everything posted by Topher
  1. 16x7 et13 front 16x8 et14 rear 225/50/16 Dunlops all around H&R 15mm spacers and longer studs, each corner Just a crappy cell shot. But I love them.
  2. Ok, I have some sweet Wat R8s that I just recently refinished/powdered. Anyways, so I purchased 15mm (each side) spacers to get the wheels to "hopefully" fit. The spacers are made by H&R for Nissan's bolt pattern and come with longer studs. I also picked up open-ended lug nuts. But as I looked at the studs, I noticed that the splines on the shoulder of the stud, the part you press in, are finer than the OEM Datsun studs...is this an issue? Thanks in advance...
  3. I have eibach lowering springs and tokico struts. Are you talking 5-10mm all around...or just on the rear? Sorry, spacing is OBVIOUSLY all new to me.
  4. For the tires, I bought Dunlop Direzza DZ101 http://www.discounttiredirect.com/direct/findTireDetail.do?cs=225&pc=28199&rd=16&ar=50 The backspacing stuff really confuses me. Some say 4" others say more... I just ordered 25mm H&R spacers for front and rear...really hoping those will work, if not someone give me a heads up so that I can change the order. The bummer is that the car is 700 miles from where the wheels and tires are...so I need them to work when I go to pick the car up and drive it home.
  5. Bump. Just had the wheels refinished. Going to do 225/50/16 on all four corners. Looking at the Dunlop Direzza, currently has a $50 cash back with a set of tires. Making them $320 to my door. Now I just need to find some spacers...any recommendations on where or who to go with for spacers? Thanks
  6. Right. And I have no problem getting spacers. Just trying to determine what size based on the equation and information below:
  7. John, were you running 225 all around? Any thoughts on the spacing considering the 13/14 offset?
  8. UPDATE All right. I think I am going to order the Watanabe RS8 today. Figuring, 16x7+13 = 4.01" of backspace 16x8+14 = 4.55" of backspace I need to space the rear out a bit ~.5" and the front ~.25 For tires, I was going to do the Hankook Ventus R-S2 Z212, 225/50/16 in the front. And the same tires, but in 245/45/16 in the rear. Reason for sizing, putting 225s would be a little stretch on a 8in wide wheel. Anyone see anything they would get nervous about?
  9. Thank you! Now I see why people are saying, 1.5" spacers. But I guess I wouldn't really need 1.5 in the front and could rather get by with a 1.25 or a 1. Right? Again, many thanks.
  10. This helps a lot. Most of the Wats I see in google image are on cars with over-fenders, something I like, but will not do to my Z. Seeing as how the width and the offset and the spacers that you picked are nearly identical to what I would run, that certainly comforts me. As it appears the wheels/tires look pretty flush on the fender.
  11. Yeah, that's pretty sweet. There are a lot of local guys on the Saab and Subaru board and we get together a lot to go run sanctioned events (autox, track days, rallyx, hill climbs, etc). Someone shoot me a pm next time you guys meet up. So back to the wheels! What do you guys think, Volks or the Wats?
  12. To further compound it... Any suggestions on tire size? 225/50 front? 255/50 rear? Man I suck. It's easy to buy wheels for my Saab. Edit: wow, there isn't much of a tire selection for that rear sizing...
  13. Oh and Goldfish, where are you at in Minneapolis? I live in NE, Mpls. In the Audobon area.
  14. I ninja edited my post. There are actually two sets of wheels for the Watanabe Specs wheel set 1 ($600): 16x7+38 114.3 4h 16x8+38 114.3 5h For the other set of identical looking Watanabe (but $800): 16x7+13 114.3 4h 16x8+14 114.3 4h (I am assuming the offset is the 13/14?, just seemed odd) Again, these are BOTH specs for the Watanabe RS8 just apparently different offset.
  15. Yes. And Yes. Assuming your questions are: 1. Are you new? 2. Did you search? Long story of the car and pictures: http://forums.hybridz.org/showthread.php?t=127874 Looking to pick up some wheels. Still a bit confused. As it stands I am on Eibach and Tokico springs/struts. I will eventually move to the AZC coilover setup. I have found two sets of wheels I am interested in: Wantabe RS8 Specs are: 16x7+38 114.3 4h 16x8+38 114.3 5h Volk GTU Specs are: 16x7+35 16x8+35 Simple question: Will these work? Loaded question: Will these work? (i.e. what do I need? Spacers and rolling fenders don't scare me; assuming it isn't drastic, i.e. huge spacers or involve over fenders, etc.) Thoughts? Thanks!
