Hi there fellow HybridZ'ers. My name is Shane and I've been searching the forum for about a year now or so. Didn't feel the need to sign on yet as I've found answers to all my questions using search, until now....
Background...
74.5 260, dropped 1 inch, poly bushings, Bad Dog frame rails,
85 Chevy 305 freshly rebuilt with stock heads, MTC1 cam, stock exhaust, Weiand Action Plus intake, HEI dist, Edelbrock 1405.
85 700r4 freshly rebuilt w/2000 stall, B&M shift kit, Brake light activated lockup
Stock R180 Diff.
And here's the issue I couldn't find an answer to in the search:
In between 2000 rpms and 2500 cruising in top gear I get a knocking sound. The sound does not occur during mid throttle or wide open acceleration. It sounds almost like a duramax desiel does under hard acceleration with the knocking. I've adjusted the timing and swapped jets out to see if I could alter or get it to go away...no dice. I get a steady 5.5 psi all the way through so I don't think it's fuel related. Took it out last night and got it up to speed on the highway, shifted to neutral and in neutral the knock still showed up at 2000-2500 in neutral at speed.
As the problem is right at the RPM range for the stall coverter, does this sound like the new stall conv is going out? I've noticed the pickup in 1st gear is dropping off slowly but until last night I figured it was a tuning issue, now I'm not so sure. I called the tranny place and got a "I've not heard of my stall coverters going out but you can bring it in..." response.
Spent the weekend checking valves, timing and jetting. Couldn't get it figured out and am looking for ideas. Anyone heard of a stall covertor knocking like a bad pushrod only at a specific rpm range?
I've spent most of the past year working on the conversion and am getting very close to being done. Thanks for any ideas!
