datsunson
Everything posted by datsunson
  1. need a door/fender free of major rust and damage, preferably just the shell.
  2. just get some aircraft thinner and a wire brush and/or white/green scotch brite pad from autozone. let the thinner set for a little and scrub away. may need to do it a couple times. just make sure to cover all exposed skin and get some safety glasses. that stuff is really good at removing paint and maybe some skin if you're not careful
  3. does anyone have it? just the ones that connect under the passenger footwell that run into the engine bay
  4. i've got an AT 77 and the 4 speed is coming off a 78. is this everything i need for a direct bolt in? searched for an hour and couldn't find this exact swap flywheel/bolts clutch assembly spacer plate tranny trans shifter and knob driveshaft trans mount & bracket clutch/brake pedal assembly clutch master/slave cylinders and hardlines
