Before I started the suspension, I found a set of original Enkei 92's with good tires to replace the shitty 80's special steelies that were on there. Then, I fired up my trust old computer, and dumped my savings account into a complete suspension and maintenance part rebuild of the car. I opted for Eibach springs, KYB struts, urethane bushings, ball joints, nylon pivot ball, tie rods.....pretty much the works. If it was a wear item, it was replaced. I went through the brakes and replaced all components, including stainless braided lines. As you can see from the pics, the rubber bushings definitely had seen better days!
I also went through and did the full cooling system (thermostat, water pump, hoses, etc), ignition (plugs, wires, cables, cap, rotor, etc), starter, alternator, and things like that!
