DMN
Everything posted by DMN
  1. How much boost can i run with a 2mm HG and flat top pistons, using mega squirt to run everything, and how much horsepower do you think i will get out of it with a good tune
  2. 2 more questions If I get megasquirt can i use the NA ecu and harness and the megasquirt EFI to run the turbo or what and how much wHp could i get with megasquirt running safe boost with the flat top pistons you your opinion (best tune)
  3. Yes i plan on running the stock head with the flat pistons for now but i also intend on getting a 2mm headgasket to lower the compression a bit, also know I will be running a nice big intercooler and bov for the setup but what i wanted to know was what i needed to get it to run, i heard something about getting a distrubitor from the turboed one and igiter its those parts that i need a good list of and with a 2mmheadgasket what boost level do you think i can run this setup at safely?
  4. Hello, My grandpa is giving me his NA 81 or 2 280zx which is completely restored and rarely driven aka low milage, I love the car but i wanna give it a bit more gettiup and i love the sound of a turbo (before i got this i was planning out a 240sx sr20det)... 3 questions 1) what are all the parts i need to change the NA to a Turbo ( I know the obvious turbo,manifold, turbo harness) 2) What ECU's can i use because i know when i change to turbo its gonna need a new one, and would the z31 ECU be the best option due to its increased tunability (and the need to a good tune when running a turbo on a higher compression)..The ECU options is really the thing that confuses me the most... 3) what WHP and torque levels can i expect with 6-8 psi on the stock t3 turbo w/ flat top pistons Thank you for taking your time to answer me -Colin
  5. Moved to the turbo section plz remove here
