Hello Datsun Z Friends,
	Long time lurker, first time caller. I have a 78' 280Z that I've been restoring for... years. I bought the car in south Ga in early 2014.
	I have a motor built by Datsun Spirit, stage 4, and I'm trying to start it finally. I have the XDi crank trigger setup V1.8. I have everything wired like the manual says, I think. I'm not getting spark.
	1. I've confirmed the dip switches: u, d, d, d, d, u, u, d.
	2. The trigger wheel sensor is <0.06" from the 7.25" wheel. I have a flat tip sensor. The sensor mount is aluminum and is on the left side at about 9:30 position.
	3. I've grounded everything(DFU to engine block, XDi to battery and chassis).
	4. I have the yellow 2 amp lead to the XDi powered from the yellow/black harness wire that is +12v run and start position, inline 2amp fuse. Spliced with a wire from 85 on 4 pin relay. I have a 10 amp fused line running to 30. I ran a ground wire to chassis and battery on 86. 87 goes to the DFU. I did the 4 pin relay wiring like so in the Electromotive manual:
	I have +12v going into the XDI on yellow wire when the car is in run position. I have a green light on the XDi unit in run position. When in the start position I have a red light. I'm wondering if the DFU also needs to be grounded to the battery?
	Can I eliminate the 4 pin relay above and try the system to see if I get spark? I am testing spark by using my timing light.
	Thank for any help. Here's a photo for what it's worth.
	Cheers,
	Jason
