VladFomin
Everything posted by VladFomin
  1. I need a fuel level sending unit from a 280z or other models if it's the same. It doesn't have to be complete or working. I need it just for the base that sits on the tank. I will pay shipping and fair price. THANKS.
  2. I'm in the process of installing an 08 STI "K" differential in my 77 280Z and ran into a small problem. The mustache bar holes on the diff cover are slightly narrower, that was an easy fix. What are people doing about the fact that the STI diff cover is about an inch shorter? I have the front of the diff mounted but its a little over an inch too short. Any help would be awesome.
  3. I'm in the middle of replacing the entire brake system on my 77 280z. New booster New 15/16 master New stock front brakes New rear disk conversion I read that I can remove the brake pressure sensor block completely. True? Also read that I can run a proportion valve from a turbo zx that had rear disks. True? Do the factory proportion valves regulate fluid to the rear wheels and the wilwood one regulates fluid to the fronts? On a stock valve is it just a pass through for the r/f caliper? Can someone maybe do a sketch for me of a factory zx valve installed w/o the pressure sensor block? Thanks
