vincentfox
Everything posted by vincentfox
  1. My 280 has a pretty good knock to but mine I pretty sure is the injector sticking check your injectors to.
  2. last night I took the master cylinder apart and the piston was just froze I put it in hot water and soap cleaned it up and this morning it was free and works fine , now I have to be a monkey and put it back in the car
  3. I figured it out I tried to bleed it and I got nothing so I took off the master cylinder and the inner seals are wore out the fluid.was just pushing back and fourth so I'll get a new master,should I replace the slave at the same time?
  4. Thanks Tony D ill try when I get home from school I have a four day weekend !!!
  5. Thanks new zed ill try to bleed the slave it is just really hard to get under the car when I have no jacks right now
  6. Just got my first car a 76 2+2 in decent shape with a little rust here and then will run sometimes! But the clutch has no pressure I'm not sure why the masters full and there are no leaks in the slave other than that the injectors are crusty and rusty plus I was wondering fuel system upgrades?
