Kongztt gt28rs MD
  • Location
    MD
Recent Profile Visitors
1668 profile views
Kongztt gt28rs MD's Achievements
Newbie
0
  1. Do you have any updates? I'm curious to what you have done for retain abs. Your post is the latest one I have found so far.. I have a 300zc twinturbo with gtx2867 twinturbos. I picked up a 370z 6speed transmission that I would like to use and the armada rear diff ~2.9 ratio seems it would be my best bet. (or an older m45 r200 3.13ratio and swap in a 350z lsd so I still have the 31spline/32mm output stubs and I will be able to use z32tt shafts so it is fairly robust throughout. Although the armada r230 is just so much larger of a unit internally.. I would feel more comfortable using that so it could handle my drag launches etc better I would think. Do you have any info on the shop that is doing your diff conversion? I may be able to do most here.. As I read of a Timken bearing that alleviated the issues of alignments/shims that one of the other members had using the z32tt lsd in armada housing. I really would like to keep ABS.. And reading about how the armada diff doesn't have provisions.. I am unsure how that would be a possibility.. Unless it's something simple as welding/machining clearance on armada r230 on a fitting to attach the sensor to the diff housing using the z32tt cover. What did you do for parts like crush sleeve etc? Any info is greatly appreciated!
  2. Would I lose abs if I use the armada r230 and swap the z32tt lsd.. Output stubs and rear cover? I read on a few pages where the abs mounts need to be pressed off the z32tt rear cover. Could I just machine the outside of the r230 armada for clearance so that the abs sensor can still be used with the z32tt output stubs? This is going on a 300zx twinturbo that I am planning on using a 370z 6 speed transmission with.. So my more desirable rear ratio is the armada ~2.9
  3. Was there ever any progress on this? I have a 300zx twinturbo that I plan on using a 370z 6speed. If I use the 3. 69 tt diff. It will be way too close of a gearing setup. The armada 2.94 would be a good swap for it. I was planning on using a 350x 3.36 rear due to the ease of the swap.. Besides welding in supports to bolt into my NA rear subframe. Or an first few m45 has a 3.13 rear but no lsd.. That would require me to buy a 350z diff with lsd and swap that. But this swap seems it would be the same amount of work and a stronger/more desired rear ratio.
