kcc0234
Everything posted by kcc0234
  1. i have; fender emblem, front bumper, bumperettes and may have the rubber as well. call me; 585-467-5105
    david
  2. As the title says...early front bumper in good condition, complete with the rubber pieces and bumperettes. Also need a passenger side rear drum backing plate for a 73Z in good condition, and one "Datsun" lower fender emblem. Since I'm feeling lucky, an electronic speed sensor for a RB20 trans in working condition. PM with any parts! Thanks in advance
  3. ............................
  4. Forgot to mention I'm looking for a set that enters the carb and surrounds the venturi. Thanks again!
  5. Looking for a six air horns for a set of 40DCOE's. Pm me with any prospects, thanks! Casey
  6. Looking for a early (non vented) hood in good condition. No rust and few dents to fix. Also on the lookout for the early 70-73 horn pad in good condition. I'm located in Columbus Ohio, let me know what you have. Thanks!
  7. Thanks everyone...found what I needed!
  8. Looking to replace a welded r200 with an open diff r200 to make my Z a little more friendly on the street. I'm located in Newark, Oh and am willing to travel a couple of hours for a good unit. My main concern is to get a diff that I can simply bolt in and go...money is too tight to run to the driveline shop!! Let me know what you have! Thanks Also the current rear is a 3.54 and I would like to keep that ratio or near to it.
  9. Thanks! That's just what I needed...time to get to work on it
  10. Don't mean to keep digging this one up, but can anyone help...just trying not to mess up my door
  11. I'll be around the car on Friday and really want to get the mirror on (the right way that is). Help!
  12. Update: Door handle/battery tray/horns are off the list. Still looking for the turn signal housings and valance.
  13. Here's a list of some odds and ends I'm trying to find: 70-73 Turn signal housings/lenses and front valance...if you're near Columbus or Cincinnati OH I can pick them up Passenger Door handle and linkage Fuse box cover (1972) Horns Battery hold down That should do it for now. Thanks for the help!
  14. I'm attempting to get an original mirror back on my 72...but the original mounting holes were welded up at some point. Could anyone take some measurements of where the two holes are located and what diameter they are. The more measurements the better, and a picture would be awesome! Thanks
  15. I'll check that out...what type of modifications did you have to make?
  16. Make that two who need this cable!
  17. If anyone has the left and right turn signal housings (with the lenses) and the lover valance that would fit an early 240 I'm interested. Parts will be painted flat black so they don't have to be perfect. Located in Dayton, Ohio. Pm or e-mail: clarkca3@muohio.edu Thanks!
