beggs
Everything posted by beggs
  1. This will be my daily driver so 900hp isn't anywhere close to what i want. Im looking for a more 400-500 hp range. If you think the 67mm is too big what would you recommend? Since it'll be my daily i want to stay out of boost in low rpm. I might go with something like this instead: http://www.driftmotion.com/2JZ-GTE-60-1-Turbo-Kit-p/dm1151.htm
  2. Datsun 240z 2jz swap questions I'm doing a Jdm 2jz swap to a Datsun 240z in the near future. Im stumped on a intercooler. I have no clue what intercooler to pick that will fit nicely with the bumper. Should i do the swap then measure for the FMIC? also just a FYI I'm also buying a drift motion 67mm single turbo kitZ here are all the items I'm going to buy: Tech 2 Motorsports 2jz swap kit and a plug and play harness Fuel Pump 1000cc or 750cc injectors- (Do I need any bigger?) Wilwood stage 3 brake kit AEM EMS New clutch oil pump and a water pump and a nice tune by UnderPressure Power and performance. Would you recommend anything else? Another problem i ran into is i was wondering if the Datsun rear diff can handle the power I'm putting down? If you reccommend I buy anything else everything helps! Thanks a ton.
