Hey guys,
New to the forum, but im getting ready to drop a lot of money into 260z here soon. trying to figure out a game plan so i dont end up buying parts cars i cant refund.
My questions have to do with hub/axle/differential conversions. I want to swap the R200 onto the 260z but was wondering if the width of stock axles from the 260 are the same size as the Z31 or if the Z31 axles are wider. I know i need 88' Z31 hubs to fit the Z32 brakes. I'm not really worried about offset and all that stuff. I have a top hat conversion for coilover suspension for the car and can adjust for it. my big thing is the easiest way of getting bigger brakes on the car. I want to know if its easier to swap the Z31 diff and axles to the car but i dont know if the axles let the hub line up with all the arms or if im going to have to buy adjustables. either way im swapping big brakes on the car regardless of how its done. rather not spend more money and time than i need to. so either entire Z31 rear end swap diff, axles, hubs, and the other tid bits, or R200 diff, stock axles (I know you have to swap the connections from the Z31 axles to the stock axles) 88' hubs and then the Z32 brakes.
As for the front end, I'm not real familiar with what all parts fit, and what doesn't. Is it possible to just swap out hubs, or do i have to do some craziness to get them to fit?? Also, can you wrap a 15" wheel around the front brakes? I assume you can for the rears because they are smaller but dont know what clearance is for the front Z32 brakes.
Thanks in advance.
