boostedZ
Everything posted by boostedZ
yea i checked for vacuum leaks, but can't seem to find it, and i check all the intercooler pipes and the intercooler itself, but nothing
okay i'll give it a shot thanks for the help
i already bleeded the clutch and it's a little easier to shift now, but grinds really bad when putting clutch into reverse. Still can't figure out why its not pulling in high rpms. sorry for being such a noob. just really confused and tired of problems coming up after another.
well im almost 100% sure that the clutch needs to be replaced, but i can't figure out why the car isn't pulling hard when in the high rpm's. could it be because the clutch isn't grabbing?
Hey guys, i'm back again and i need help with my 1983 280zx turbo with hopefully the last problem i'll run into. i couldn't rev past 3k rpm and my car always died coming to a stop. Well the TPS fixed those problems, but now my car is hard to shift into first and reverse, could it be the clutch? also, when i do get it in gear and i'm punching it at WOT, the car pulls, but not as hard as the first time i test drove it and i hear the turbo sucking in a lot of air but no GO. could it be that the clutch isn't grabing it? please help thank you in advance
Oh okay, thanks guys I'll just go order a new one and play with that old one.
So i think i found my problem on my 1983 280zx turbo. I've gotten multiple people telling me its the TPS and im starting to think it is also. My question is how do i adjust it? the online book says to take off the black cover and check to make sure left and right metal is touching the center at the right time, but it seems like the black cover can't be taken off or can it? also, do i have to take it off or is there a way to adjust it by hand?
okay i'll look into that, i think thats it though, because after fixing the head gasket, the plugs were not in the correct spots as stated in the online book and i'll probably have to adjust the tps while im at it. i'll update on what happens after i switch the plugs and adjust the tps thank you so much texanredneck for all the advice, help, and quick reply
okay cool thanks, i'll check on getting bigger injectors. also my tps sensor connector only have 2 plugs, which plugs go into which one, because i see 3 spots on the tps. i looked on a 280z fuel injection book online and it says to put it one on the farthest left for the FULL THROTTLE CONTACT POINT and one on the farthest right for IDLE CONTACT POINT. if someone can tell me if thats right or not? also, what is the middle spot for on the tps then?
so your saying it could possibly be the injectors, im a noob to this car, im a honda and acura kinda guy. i think the car is running lean because when i check the #1 spark plug the arch was pure white, so maybe im not getting enough fuel??
i don't know what the fuel pressure was at, i'll have to ask my dad when he gets home. also, if it helps, the car has been modified by the previous owner, i remember correctly he said he put Crane CAMS, upgraded to a front mount intercooler, added MSD, koyo radiator and some kind of fans
theres no housing for the connectors, but they are plugged on the tps, i think its working fine because when i tried taking it off the car dies, but put it back on it idles fine and my dad check the fuel pressure, he says its fine. ohh and we got the car to stop dying, now just have to figure out the stall at 3k rpm.
i don't think i have an exhaust leak because we checked and couldn't find any. also, i never messed with the tps position, but what is the correct position its suppose to be in? i hear the turbo sucking A LOT of air but it just doesn't go please help someone. i searched through other threads but they talk about water in the tps and i don't have that problem
well, i just finally got my 1983 turbo 280z to run and everything seems to be fine, engine runs normal, but when i'm in gear the rpm doesn't want to go pass 3000 RPM. the car still moves, but slowly and pressing on the gas does nothing. im totally lost on what it could be. anyone have any thoughts? also, when releasing the gear coming to a stop, the car just dies. could it be my EGR valve? or something else? also when im in neutral the rpm is fine, i can rev it freely
also, i have been cranking the ignition for long periods of time. what is "the ol' ECE External Combustion Event." could that mess things up, if so, how would i know if it did and how to fix that?
the car was running fine before we replaced the head gasket. first we set the cams just how the book told us, but it wouldn't run, so then we tried setting the cam on the number 1 center point like how the previous owner had it, and the plug and crank is set just like the book told us. i'm not sure if the plugs are firing at the top of the compression stroke or exhaust stroke, how would i check that? im totally lost on what to do. i tried falling the book and putting it back the way it was from the previous owner. any other ideas? thank you all in advance
well we just took everything off again to make sure everything was correct and it was, but the car still won't start. everything seems fine, and seems to be working but it just won't start. we have fuel and spark. anyone have any ideas for me to try? im at a breaking point right now thanks
yes my dad said he did do that, so we're really confused rite now, we can't figure out the cause of this, we align everything like the book and when we go try and start the engine, it slips.
hi i need some help with this. i have a 83 280zx turbo and just changed the head gasket, but when we put everything together, the timing chain keeps slipping twice already and won't start. what can i do to make it not slip? thank you in advance.
okay thanks guy, so take off the fill plug first then the drain plug. i'll try that
the car is already a 5-speed. anyone else have some info for me thanks and i got the car with no service manual
im new to datsun, and just wanted some help on this. i need to flush my transmission, but don't know how to find it or do it on this car. can someone please help me with how to do it and locate it please thank you in advance. Kevin
