Hi there,
	1982 280zx Turbo
	Car was running rich at idle, then it seem to switch to running lean at high rpms once it built boost.  I was going through the engine bay and replacing connectors, they had started to degrade, some were missing clips and some had started cracking, I also was cleaning connections starting with improving the electrical connections to see if that cleared up my issues.  I was doing one connection at a time, and then testing the car so I would know what fixed my issue, if anything.
	First item I rewired was the AFM Connector.  Fired the car up and it ran terrible and was smoking.  I shut it off and started to look.  I realized that I had wired the AFM backwards.  So if - was = to an open pin on the connector, and | was where a connector was an occupied pin, I wired it |||-|--, instead of --|-|||.  I rewired it properly and restarted and it continued to run very poorly and die.
	I have checked the ECU where I though a resistor maybe had blown
	I had replaced the Fusible Links with a maxi fuse set up and those checked out.
	I ran through the FSM Tests for the AFM and it has checked out fine.
	Im not sure where something else could have went wrong.  I am imaging the engine ran very lean when I had it hooked up backward and that explains the smoke out of the turbo and Intake so I could have done serious engine damage.
	I need some ideas of where to go from here.  Is there something else inline with the AFM that could have been effected by my mistake? I havent tested fuel yet, but that wasnt a problem just minutes before I miswired the AFM.  I have ordered a Fuel Pressure Gauge.
	Any help would be appreciated.
	Thanks!
	Kendall
