Destabilized1887
  • Location
    southbury Ct
Destabilized1887's Achievements
Newbie
  • One Month Later
  • Week One Done
  • First Post Rare
  • Conversation Starter Rare
Recent Badges
0
  1. i still have to check i have good wiring to the ecu but the chts sensor read 12k ohm after being in the freezer and 237 in boiling water i was told this is in spec for the sensor so it should be good
  2. hopefully this is a quick one, I believe the issue is in the afm or the ecu at this point title says it all pretty much, I've been chasing the issue with my s130 where it randomly started running super rich and died while driving i managed to get it going again and it would die under 2k rpm so I red lined it all the way home i pulled the engine apart because it needed valve seals and a timing chain, i replaced a bunch of gaskets and checked my compression while I was at it compression was good across all cylinders in the 145-155 range i replaced the fuel pressure regulator and have it set at 30 psi idle and 36 cranking new plugs wires cap rotor O2 sensor and injector seals none of the injectors are leaking and I disconnected the fuel line to the cold start valve to eliminate that factor the afm was replaced about 3 years ago now so I have a hard time believing it is the issue car will struggle to idle at 600 and blow black smoke while it runs, if I cause a vacuum leak it runs at 1900 and no more smoke, and if I turn fuel pressure down to 20psi no more smoke neither of these things are a solution to the problem and im at a loss so far
