After being notified, I’ve reposted this as my last post was unable to be replied to. I’ve tried looking around on Reddit, ZCarForum, and here but cannot find a definitive photo or description of what harness the wire for the temp gauge goes through on a 1978 280z. A few of my harness ends have previously been chopped off - presumably for parts. Comparing to my 75 I was led to believe it would be a yellow wire (per FSM) routed with the other thermostat housing sensors on the FI harness, but could not find it when peeling the wire wrapping back, just the temp sensor and thermotime switch. When I asked on Reddit I was told someone thought theirs was part of the front left harness with the headlight wiring as a green wire, which unfortunately for me is chopped, I saw two green, one going to the distributor and the other being chopped. With the key on I grounded it with a small fuse in line and nothing happened, gauge did not fluctuate and fuse did not blow. Its possible this could be the wire with an open somewhere along the line. For anyone with a complete harness could you trace it back to the main harness and take a photo or point me in the right direction? Thank you.
	TL;DR 1978 280z where does the temp gauge wire connect into the main harness and what color is it?
