MinneZota
Everything posted by MinneZota
  1. Thanks for the reply! I apologize, I should have included more info. The bigger wire (on the left) is the 12V wire coming from the top lighting switch. The reason it’s cut is because when I went to disconnect the old bullet connections, it must have overheated in the past with the halogens and melted the connection (so it needed a new connector anyway). The wire on the right, the smaller one, is the extension wire from the ATO fuse holder, I removed the connector to show the size difference. I would absolutely love some help with this if you’re willing. I can message additional pictures and videos when I get home to give you a clearer view of my situation.
  2. Hi there, I am running the Holly Retrobrights on my 1978 280z. Currently I have lowbeams and high beams at the same time, but if I switch to just low beams, I have nothing. I also do not have running lights at the headlights, just high beam. So here I am trying to construct your creation! I am running into a few issues. The Red 12v wire from the top switch seems to be 10 gauge wire with matching 10 gauge bullet connectors. How did you get these two to connect with the connectors for the 14 gauge wire connectors?
