corolla turbo
Everything posted by corolla turbo
Shocks same S12 silvia and 280zx?
corolla turbo replied to corolla turbo's topic in Brakes, Wheels, Suspension and Chassis
so you think i should buy these absorbers what "KYB euro database" says. and not the US partnumber. -
Hello from germany I need for my euro 280zx 2+2 new front shock absorbers. I tryed to find in germany KYB`s but nothing available. nothing else available. I watched at german kayaba.de page and they showed partnumber 365031 After this i watched in USA /ebay.com and ther is for my 280zx thes parnumber 365013 dont understand? i am little confused? the other partnumber should be for silvia S12 but why got euro ZX other inserts than US cars?
i searched a little and found a thread about "header math"....there are some good links posted. What Outer Diamter gote pacesetter heades? at the links i found some calculation...i should use 38 or 40mm ID tubes for my OEM engine.Because max torque ist 4200rpm. Streetcars are normaly used in low and middle rpm. so the header should work in this RPM range until 5000 at best. With too big pipes i loose NM at low rpm. IS THIS CORRECT?...and it seams to be good idea using longer pipes?
Hello, My original header is blowing. Now i want to put in upgrade one. My engine is completely original only new sealed. Waht Header would be an good upgrade? whatched At kameari but they told me the Drag header is not good for my standard engine. I searched more and found "Pacesetter Header" and "Hitech Header". What one will be best? Hitech gives more power? or is this only kind of replacement? Fom ebay i bought long time ago Cheap Haeder looks like Pacesetter, but there is a sticker on it, Made in Mexico. This doesnt fit my 280zx. Htink its form earlyer Z. what kind of header i should make. In germany is nothing available so i have to build my own one planing Primaries 45mm and 2mm thickness. Is this ok?
i need new vac control for an 1980 ZX, this should have partnumber 22301-N4700. later ZX got 22301P7901 until now i didnt found an control for my car. 2 sellers at ebay sell VC351, but they dont ship to germany what is difference between both. they look same. can i take later one without problems?
i need new vacuum control assy for my L28E distributor. Used google and found one part at rockauto.com. when i put it into basket and want to order, it was automaticaly deleted. Part is not available. i saw the manufacturer Standard Motor Products VC351 . googled this evening again, but most pages show only 280zx until 1979??? will this part fit my 1981 car? any other option to get new part?
distributor 1981 and 1983 (Pics added)
corolla turbo replied to corolla turbo's topic in Nissan L6 Forum
today i remuved the throttle body and watched everything very accuratly. In front the throttle is an little hole and one blind hole at the body but isn`t blind. There are several holes in the body but no one gots an connection to fit an vac hose. Even the working hole doesnt have an connection, only an hole. So i fitted an brake bleeder screw. i realy dont know how the vac pipe is OEM fitted. I found also an american parts page. but the 2 european VIN doesnt work. so i`ll try next week to ask at local nissan dealer here some pics -
ok, so i got an JDM engine. but why is no vac piping istalled?? or gots JDM engines other distirbutors? at what point of engine running the vacuum actuator works ? i couldnt find any informations about its working at idle is high vac in intake and the actuator is going to be shorter (changes ignition) at higher REVs is less vac and the actuaror goes to max length??? where can i get an Vac connector? behind throttle somewhere at the intake i think?? my engine lookes like the one on the picture. No EGR, no cat,no detonation sensor, no exhaustsensor -
ok, thank yoo. but i dont understand why i couldnt fit the vac piping... i looked little at several pages, many different engines are available, all are L28E. some have an EGR system, i looked at english manual from 1983, my throttle lookes like from eccs models but i have no emission control.all hoses at inlet are used, nothing is damaged or left. LOOKS very OEM -
the 1983 one is an NON TURBO with OEM flat top pisons and P90 head without Catalytic Converter it makes 150PS. the oilpump shaft is same. I already installed the distributor, but couldnt find any option to connect vacuum hoses to the intake sytem like before.that is why i was little confused i think the europeen zx are little different in some smale parts will there be an problem if i use the distributor without automatic time adjusting? -
hi, i got an 280zx from 1981, which i restored. An damaged zx from 1983 i used for spares. I only got the 1981 Distributor with vacuum actuator. this i installed. Now i want to use the 1983 engin because i rebuilded it. BUT THE DISTRIBUTOR ! ! 1983 engine doesnt have an vacuum conector for the distributor. i`am little confuse because 1983 doesnt change ignition with higher revs? is this true? i think about making the vacuum actutor doesnt work (leaving the pipe disconected). think this can work?
my L28E-head was at local engine builder.they shaved 0,25mm and grinded new valve seats. BUT the removed the camshaft bearing from the head. I read at the engine manueal that these parts doesnt have to be removed?!?! the cam towers are centered with sleeves. so it shold be possilbe to make it like it was before??? someone can tell me tightening torque of the cam towers? i read in this forum, if i shave to much from head, i have to use spacers under the cam towers. but this will mean to remove it. I`am little confused are 0,25mm (0.01") to much without cam tower spacers? do i have to use such once now??
Hello, i need the left front axle housing (like right one at picture) in good used condition for an 280zx 2+2. Only need the axle housing, without shock absorber shipping to germany is a must have. how is this part called?!?!
Rear suspension question
i got 2 cars, one broken and one for restoration. i decited to use the shocks with sticker "Monroe". they seamed to be newer and better. so i sanded it and paintet is black (left one) the right one was in my car, which i restored. Now I think this is OEM 280zx one?! -
hi, following problem: My 280zx 2+2 is lower at the rear axle. I decited to put in new stronger Springs. Today i removed the Rear shock absorbers and wantet to put i an old one with spring to have the car moveable. When i watched both i saw the 2 shock absorbers have different size (Picture) I bought the car like it was, dont kwon who repaired it before Is it possible that someone put i wrong absorbers?! springs seam also little different what is the OEM absorber? can someone see it??
I have an N42 head at my actual engine. this is L28E from 1981, OEM dished pistons and N42 head. I think can take these head, with my 1983 flat top pistons but i think this will make to much compression. Because OEM ECU doesnt have an knock sensor. i have no planed CR, think oem is 8,8:1 ? this is ok but little more doesnt kill the engine. but shving a lot, makes timing problem. because of this, i asked what i can shave without have problems with knocking an timing we have 95 octan an 98 octan. best is 102 octan but very expensive. so i only use 98oct
i found spacers fpr the cam towers, witch are needed after cylinderhead RESURFACING. but 0,02 Seams very much? i only plan to shave a little, dont know whats the minimum the engine builder can shave
i am at restoration at my L28E from 1983. is hat P90 head and flat top pistons. Now iam thinking about shavin the head to raise the CR. but if i shae 0,02" (0,5mm) i got much timing problems??? does i also have timing problems if i only shave litte 0,1mm to the the head 100% plan. I know i can put spacers under the cam towers, but du i need these also with little shaving or only i shave 0,5mm
so you all mean ITM is good choise? ill try to get these. thanks
Makes ITM good quality? these i can get from ebay. also ROCK is availabvle in ebay, for little bit more money. i only got an oldtimer, which i drive in summer. Dont have an racecar, no high CR engine. I only want good OEM engine whicht doesnt burn oil
I need new piston rings. In germany nothing is available.whith what brand you got good experiences and what is trash? looked at ebay.com and found Rock Products Inc ???? i need rings for 1983 280ZX where can i buy pistonrings? some online shops?
hello, i need for my datsun 280zx, 2 of the 4 hood bumpers witch are mounted at the fenders. should look like these I also need one inner black clip for the Rear Interior Roof Panel and shipping to germany must be possible i can make pictures what i need, if someone dont know what i exactly need please help me
I have much oil consumption at my 280zx. Head is already new sealed. Now i have to change pistonrings. engine rum 190.000km. but it have tu run some km more for some years. I only use car as oldtimer on weekends. no track car. I am planing rebuild another engine but iam out of money, only rings possible. I know this isnt perfect but these engine must run for 2 or 3 years What piston rings i should buy.? Looked at ebay, there are 5 brands: Hastings,Rock, ITM,NPR, grant. The nissan dealer gave my partnumber for my car,the only seller which wrote these partnumber ( 12033-P8370) is NPR. and most piston rings are only 280Z and until 1981. now my questions: What brand makes good stuff`? Does all L28E have same ring size? one set is form 75-80 other 81-83. my 280zx is older version with "crome bumper" from 08/1981 Can i use anyone of these ore only one specific set? edit:as i know know, one ring is different 75-80 ther is 2x2x4, 81-83 there is 1,5x2x4 nissan gave me with VIN part number 12033-P8370, but this would mean i have ring 1975-1980. My 280zx first was license 08/1981
eibach..sounds good, but not available in germany. dont know why.
Hi, is it possible to fit 300Z springs in an 280zx? In germany nothing is availabnle for an 280zx and the OEM springs are very uncool. THe car must be lowerd. 30mm are enought i think.
