Search the Community
Showing results for tags 'cutting stock springs'.
	I have a dilemma and I have discussed this with many car experts. The results are mixed, so I thought I would post this question again because opinions are very mixed, only causing more confusion regarding this topic. I am not interested in putting my car on the track but currently its stance is ridiculously high with an enormous wheel gap. All the after market lowering springs currently available will only on average lower my car by at best a little more than an inch which will not help me with the over 3 inches of gap I am trying to eliminate. Quality adjustable coil overs are extremely expensive and also require fabrication/welding/butchering my original Z car which I would like to avoid. I have been told that if I have to try cutting springs I should avoid using heat to cut the springs and only remove a quarter coil at a time. Also, I am not sure if it is better to remove a section from the top of the spring or the bottom? This type of lowering alteration has been done for street and track cars for many different makes of cars with success. Anyone willing to share their positive or negative experience and tips, particularly with Z cars in the years between 1975-78, would be greatly appreciated. Through reading a lot of these forums, I also am concerned about creating camber issues.
