Search the Community
Showing results for tags 'oil starvation'.
  • Search By Tags
    • oil starvation ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. Improved Racing's new billet crank scraper kits and windage trays will be available next week. These kits are a big improvement from our 1st generation scrapers. We have a lot more applications, and they are completely bolt-on for most common setups, including 4" strokers. If you are building a st...
  2. A pinched or improperly seated oil pickup tube O-ring can allow the oil pump to suck up air, resulting in oil pressure drops and oil starvation. This is common a occurrence in the GM LS engine family, as the pickup tube is secured on only one side by a single screw. Improved Racing now has a bra...
