Dan_Austin Posted June 3, 2011 Share Posted June 3, 2011 I've been watching the Megasquirt development for a few years now, and the projects listed here at HybridZ. I have been a bit surprised that the microsquirt has not popped up even once as part of any of the installs. The V3 revision of the hardware expected this summer is supposed to bring full weather proofing to that table, and a slight reduction in size. It looks like it would fit nicely on the back side of the fusible link bracket, where my original voltage regulator was, with the option to mount an EDIS module on the other side of the same bracket. I know this is a group of twiddlers, and perhaps the Microsquirt is too limiting in the long run, but I wonder how many folks here have started with an MS2 and an EDIS setup then later decided to move to COP with sequential (which appears to be the major option I would be giving up if I went this route)? Quote Link to comment Share on other sites More sharing options...
dexter72 Posted June 3, 2011 Share Posted June 3, 2011 I remember microsquirt being more for motorcycle engines, something about how many injectors it controls and if there high or low impedence injectors. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted June 13, 2011 Share Posted June 13, 2011 If you stick to high impedance injectors, MicroSquirt will run them just fine. With the Extra code, it is possible to make the WLED and ALED outputs serve as spark outputs to run wasted spark as well, although you'll need a pull up resistor. While there isn't much of an upgrade path for a MicroSquirt, it is fairly capable. Quote Link to comment Share on other sites More sharing options...
