ComicArtist Posted June 19, 2011 Share Posted June 19, 2011 (edited) So I'm almost done with my ET swap, and I'm down to the wiring. I've been reading the wiring guide right here: http://forums.hybridz.org/index.php?showtopic=38461 And under the part for wiring in the FI relay, it says to splice the three wires to 12v switched, 12v constant, and 12v switched for 5 seconds. Thing is, it doesn't say which wires to splice those to to get the desired effect. So..... are you guys just running them to the fuse box, or are there certain wires in the harness I can run these to? Thanks! EDIT: running into more problems. I've gotten to the ignition wiring, and I'm running into some problems. I'm using the engine harness from the '81, but can I use the ignition harness from the '78? I don't have the ignition harness from the '81, but it seems like I should be able to use the '78 ignition harness. Thanks! Edited June 19, 2011 by ComicArtist Quote Link to comment Share on other sites More sharing options...
