FOUND POWER WINDOW CIRCUIT BREAKER
;)FYI ANYONE THE @#$%%!POWER WINDOW CIRCIUT BREAKER IN MOST Z,S AND ZX,S.IS LOCATED BEHIND THE FUSE PANEL ON THE RIGHT SIDE YOU HAVE TO REMOVE A LOT OF STUFF AND UNSCREW THE TWO SCREWS THAT SECURE A BRACKET THAT IS TUCKED INSIDE OF THE CAVETY THEN PULL THE BRACKET OUT AND ON THE BOTTOM IS YOUR CIRCUIT BREAKER,AS WELL AS A RELAY
