vent hose for fuel cel
slowride
Hello,
I have a fuel cell installed in my trunk and i am wondering if there is a way to hook up the vent so the motor will burn off or suck out the vapors from the cell?
Also is it possible to wire a aftermarket cell/pump/fuel reader to a stock guage?
Thanks!!
Edited by slowride
You could connect the fuel cell vent to the air box. That will not "suck out the vapor but it will contain them a bit.
The fuel gauge can be used with a fuel cell. The main issue is the sending unit resistance. You will likely need to use an aftermarket gauge and sending unit to get a reaonably linear reading.
